Hi
After upgrade my xperia min i have facing a problem with battery.
When battery status 30 % it showing low battery and get switched off.
When i pluged in for charging ,,, charging status startEd from 30 % .
Plz let me know y this happening...
Solved! Go to Solution.
hi,
notice your battery level and remove your batery , wait for 2 minutes and reinstall the battery
observe the battery level, u will see 30% change in battery
your provblem is solved, charge your battery to 100% and u will never face this problem
keep us updated
and try this also..
charge it to a 100% , remove and insert the battery , you will see 85% battery level , charge it again to 100%
and it will never happen again..
Try the tips nabeelraza and slimshaddy posted. Let me know if you still have the problem after this.
