Hello everyone,
Am new to the sonyericsson brand but not smartphones as i currently use a nokia n900,my SE Play cant receive files using bluetooth even though i can send i enable everything but cant receive even within the 2 minutes allowed,every device i pair with only goes one way.i cant even receive contacts sync with BT from my n900 any help will be divinely appreciated.
Solved! Go to Solution.
So what happens if you try to send a file to your Play?
Do you get any icon in the notification bar? If so drop it down and accept the incoming object.
Hi johan
just solved it with the drop down line you used.thank you
