Camera PIXEL problem
MaxiMiniPro
Hello ı have this pixel problem does anyone have any idea of this problem ? what can ı do ? beause ı have last few months warrantly and if this is problem ı can send service ...
Check the video !
Video
MaxiMiniPro
OKey thank you ver much Slightly_smiling_Face
15 REPLIES 15
profile.country.RO.title
_alexdon_
You need to reupload or edit the link,it is not good.
alexdon
MaxiMiniPro
Soryyy , ı updated now
_alexdon_
I cannot see any problem.Could you explain for what I should look?
alexdon
MaxiMiniPro
I mean sometimes ı see some green colour on my screen you can see in video at 0:10-0:15  or 0:23-0:27
_alexdon_
Oh,it can be hardly noticed in the video.Do you have automatic brightness on whitemagic enabled?
alexdon
MaxiMiniPro
Yes , its enable and automatic brigtness
_alexdon_
You could try to disable it.See how it goes.
alexdon
MaxiMiniPro
I couldnt found to disable it Slightly_frowning_Face ı can just change , automatic , daylight , cloudy ... and when ı change it there's no difference about green or black or some pixel colour Slightly_frowning_Face or how can ı change another settings ?
_alexdon_
Go to settings-display,there should be brightness and do not set it on automatic(whitemagic platform).
alexdon
