Can't update to 4.1.B.0.431 from PC Companion
Hi, what can be a problem with updating my telephone from PC Companion, after preparing to update i see message with next contain...
Can't install or run software component updates the phone.
And where i can send a log file about this program error?
Thx for help!
Nabeel
Master
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
________________________________________________________________
Nabeel
Master
                  or
