i cant update my neo v from 2.3.5 to 4.0..its showing error while downloading update in pc companion in my pc...pls help
Solved! Go to Solution.
Hi, I believe you meant was from 2.3.4 to 4.0 .... You may want to use Update Service to update your phone. Here's the download link, http://www.sonymobile.com/gb/tools/update-service/.
Keep us updated.
Keep us updated.
thank you very much..it worked!!!
Great!
I'm not getting even with this software .. says it's the last version, but version is 2.3.4 ..
I'm from Brazil, is it because of that? ... but I tried with the English language well and did not too...
(excuse my bad english )
thanks
it doesn't matter if you change the language, 4.0.3 it's only available for the Arc S, not the Arc. The Arc will get 4.0.4 sometime this week in certain countries and then it eventually you will get it, if you are locked to a network, it's up to them to decide when to release it, and if they want to release it.
if you want 4.0.3 right now this is an option here
http://talk.sonymobile.com/thread/35964
Don't forget to mark theCorrect Answers & Helpful Answers
my device is NEO (mt15) and not arc..
I can manually update to use the arc as a reference this link?
thanks again
my bad, no you can't update to 4.0.3 just yet but keep an eye on this thread
How to manually update 2011 Xperias to android 4.0.4
http://talk.sonymobile.com/thread/38251
as soon as the update is release I will post the links
The links of the official Neo ICS 4.0.4 was released?
Android 4.0.4 hasn't being released yet.
