I cant access the Internal Memory of my Xperia Sola in my PC. I used to get the autoplay pop up on pc after connecting phone, now nothing comes up.
Internal Memory is also not appearing in "My computer" as a Drive to access it.
What went wrong?
I tried on 3 computers and same problem 😞 Any one has a solution to this??
Solved! Go to Solution.
Try USB Debugging...
Settings > Applications > Development
...and remember to mark Correct or Helpful answers if you find them useful...
Do you get any response from the phone at all when you connect it such as charging etc?
What are your thoughts about this forum? Let us know by doing this short survey.
Yes, when i connect it to my laptop, it says "Common charging".
Sometimes the auto play pops up for a fraction of second and goes away.
I now tried on other computers and its working but only in my Laptop it wont. Any idea what is the solution for this?
As per Trubo_XL, I enabled the USB Debugging mode and it worked in my laptop 😞
hey Thankx, you are awesome.
Enabling the USB Debugging worked and I now get the Auto play pop up and can access the Internal Memory of Sola in pc.
It works in my other computers without USB debugging thing, any idea whats the catch?
Settings > Device> Xperia > Usb connectivity > Install software
