Freezed a few things in titanium backup, now xperia pro won't boot
As the title say's I froze a few things that I thought would be non critical fluff like the facebook integration, etc as I don't use them at all and the phone then won't boot and just hangs at the SE logo screen, is there any way I can reflash the stock ROM?
Uliwooly
Here you go
http://forum.xda-developers.com/showthread.php?t=1089470
make sure that you mark the Correct and Helpful Answers
6 REPLIES 6
Never mind, that repair phone function of PC Companion has been found and used. Don't suppose anyone has a list of what is safe to remove from the stock ROM?
Jake-SonyXperia
Champion
Good news that you resolved the problem. :smileygrin:, Sorry I can't help with the list of applications but I'm sure someone here will be able to provide this information.
Uliwooly
Here you go
Uliwooly
this is the latest firmware and how to backup everything before you start deleting apps and what not Dizzy_Face
http://talk.sonyericsson.com/message/140384#140384
Thanks, that is exactly what I was looking for. Never thought to look in the arc section of xda.
this link http://forum.xda-developers.com/showthread.php?t=1089470
will give you a list of apps that can be removed, others that can be replaced others that should NOT be deleted
