Since I have updated my phone to Android 4.0.4 it has problem.
The phone freezes itself several times and remains the same for 2-3 minutes, then it reboots. ´Just today, it happened 3 times during one hour.
Before updating to this new Android, everything was working fine.
Solved! Go to Solution.
If the problem still remains I think you will have to get the phone checked by a repair center. Contact your local support team for more info.
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
Do one thing, format your SD card and reinstall ICS as follows
________________________________________________________________
Backup everything as it will erase all data on phone (sms, contacts,apps)
Update/Repair your phone via PCC or SUS
PCC (PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to).
Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
PC Companion http://www.sonymobile.com/global-en/tools/pc-companion/
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
Should I use both PCC and SUS?
Just one, use any
I used SUS. But the problem persists
did you format your SD card as well ? before using SUS ?
I have some SMS and photos. If I format the SD, they will be lost.
Oh my, :smileymischief:
You can send them all to pc, after sending the files to pc, format your SD card, after formatting send back all the stuff to the memory card
Copy all contents from memory card to pc and format it. later on send the stuff back
I see.
And could you tell me about taking backup from my SMS?
