How to check picture size?
Focuscar
Hi, sory for noob question but how do I check the 'size' of a picture using the Xperia Picture Gallery?
I have an Xperia Neo MT15i, & I really can't find this information anywhere - choosing 'picture details' did not display size info.
Any help? Thx.
Nabeel
Master
So true
Unfortunately there is No such option in Xperias Gallery
But on ICS we get another gallery that would provide you with such options
So either you will have to wait for ICS or install a third party app from google play
Nabeel
Master
So true
Focuscar
-.-" ok thx.
