Hi
How do I check my Xperia P serial number as its have a non-removeable back. Is there some other way around?
Solved! Go to Solution.
the cap bellow the transparent bar thats were you find the SI number
Don't forget to mark the Correct Answers & Helpful Answers
now that's an intersting question I wonder if you have to use Service Menu for that
http://talk.sonymobile.com/message/113787
I can enter the Serive Info Screen. But there is no serial number in any of the menu.
are you sure? service settings > software info >
There I have
Phone Software Version
File System Version
S1 Boot Version
ETS Software Version
Customization Version
Active Customization
Memory Card
Content Version
Type Number
Which one is the serial number?
to be honest I don't know let me look into this
Ha Ha Ha.. No Issues...
remove the bottom cap, what do you see?
You Mean the back cover or cap below the transparent belt?
according to the FCC
https://fjallfoss.fcc.gov/eas/GetApplicationAttachment.html?id=1669622
you should be able to see it
