How to create a new photo album?
Hi there,
I'm looking for some help creating a photo album, I've tried all the combinations of keys or options that seem obvious but there's no result.
I'm basically looking to do a really straightforward thing, to create separate albums in my Arc S for related photos.
Can anyone help me with this? There was no manual with the phone (strange) and the electronic manual makes no mention of it.
Thanks in advance,
Tryp
suze
Leader
You can do it two ways, firstly from within the phone download a File Manager.... Astro, Linda, ES there are loads. Personally I use Astro.  Then create a new folder within the Picture file and move the pictures there.  They all give you a multi select function so you can do it more quickly.
The other is to plug in to your PC and use Windows to create new folders and cut/paste etc in to them.
When you open the Gallery they will then be shown as seperate albums.
Hope that helps.
5 REPLIES 5
suze
Leader
Hope that helps.
andygino
Hi
I have the Experia Tablet Z, and want to create a new picture album or arrange my photos in a different order for  business presentations, which there seems to be no facilities for this?.
I'm not sure which programmes to download. You mentioned File Manager or 'Arc', but how do I get to that.
I can go to File Manager on my PC, but where is it on a Tablet ?
dly
I have moved a set of pictures to a new foldee onsode the images folder, I have tried to move it one level up but still I don't see any new album being createdx
The album app already has multiselect it makes no sense to not have Albums management built in
annie3806
I would like to categorize my photos.  On my pc I can drag and drop in different folders.how do I do this on my tablet.
My photos in one big jumble. Please help.
profile.country.RO.title
_alexdon_
Why are you using this topic if you have a tablet?You just need a file explorer,like androzip or es file explorer.
alexdon
