ics update dont found
Why cant i find the ICS update for my neo? my si  is  1246-9898.
Nabeel
Master
Wait for 2-3 days and see if the problem exists
Try to use this
________________________________________________________________
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
Nabeel
Master
Try to use this
                  or
