Solved! Go to Solution.
No,that is not possible by default.You can check XDA for more info:
http://forum.xda-developers.com/showthread.php?t=1659231
Android does not need that much free RAM.It is good to use the RAM it has got,that way the processes start faster.I have left you a link,it seems you can swap some memory from a SD card.But I would not count on that.
Anytime,if you decide to try something like that,tell us the result.
