Lost the messaging icon on the front page
MiaKjr
Hi
I seem to have lost the icon that takes you to your messages...that is present at the bottom
It didn't help to restart the phone and I can't restore the icon back, since it's not to be found...either at shortcuts or applications.
I have rather important message, I would like to get back!
Help!!!!
Uliwooly
Don't freak out
settings > apps > all > scroll to the bottom > messaging > Enable
Voila, done
Don't forget to give Kudos
7 REPLIES 7
Uliwooly
Don't freak out
Voila, done
Jac
I deleted icons from the main panel by accident and figured I coudln't get them back but I discovered that you could open the app drawer (centre icon on the main home screen) then find messaging in the list, press and hold the messaging icon and drag it to the 'add to homescreen' bar that drops down from the top of the screen.
profile.country.RO.title
_alexdon_
You can drag any item from the menu to the main screen,and also to the down bar.
alexdon
Ayda
Thank u
it works :smileysmileythumbsup:
@uliwooly wrote:
Don't freak out
Voila, done
Tags (1)
Bluebells14xx
I have a hawaii Y5 and the icon has gone altogether.and I done what was said above and it won't let me drag it over...I send a message from another to mine and I can't seem to get it even does its sent...any one know of what I can do to get them back....
Syazzwoo
My phone lenovo vibe s1 lite the dielae icon missing please tell me what to do
honeygramz42
this solution didnt work. the messaging app was not in the list.
