Hello Sony
Yesterday i installed the 4.3 update from Sony. Today my Phone reboots about 4 times an hour. Saying sim/uim and sim/uim inserted. .
Factory reset don`t work! (approximately one day work then start rebooting every 5 minutes)
PC Companion repair don`t work! (approximately work one day then start rebooting every 5 minutes)
Seus don`t work! (approximately one day work then start rebooting every 5 minutes)
Tried it by pulling it out and putting it back several times! (approximately work 2-3-4 hour and then again....)
and sometimes phone lost gsm network, but it happen relatively rare
Is there someone Who can help me?
Solved! Go to Solution.
Try with another SIM inside for a couple of days.
i tried already with another sim one week long, got the same issue
You can try a software repair:
http://www.sonymobile.com/gb/tools/update-service/
Or just take it into service:
http://www.sonymobile.com/global-en/support/contact-us/
alexdon, I have downloaded update service app but Xperia T is not on the list. Do you know why? I have T2 only
You are using most probably W8 or 8.1.In that case,you need to run SUS in compatibility mode with windows 7.
Ok alexdon, thanks for the help. Already did it and hope it's ok now.
Good,you should report here if it occurs again.
Replacing the SIM and using Android 4.3build number 9,2,A.1.205 I can report that my Xperia T has returned to being a reliable phone, and the battery is not draining as quickly compared to the very problematic original 4.3 release build.
I'm using sony xperia lt30p with build number 9.2.A.1.205, Kernel version: 3.4.0-perf-ga3976ea BuildUser@BuildHost#1Thu Jan 23 15:33:50 2014
My mobile is rebooting several times in a day. Please send any update firmware for this.
Thanks & Regards,
Pavan.
Hi Dears did anyone find the solution of this problem , when mobile is restarting every 5-10 minutes /writing sim /uim card inserted ?
If Yes please telll me how
Thank you
