hi guys
i have xperia t2 ultra i bought it few months ago and it worked perfectly with me till few weeks ago
it starts to restarting by itself every 5 or so min and i tried to reset it many many times but it still restarting by itself even after that so i removed the sd card and still do the same thing so please what can i do to fix it??
Solved! Go to Solution.
The SIM has a LOT to do with that, if the SIM card its defective it will restart the phone.
um i didnt try that ..... i will try it now but what the sim has to do with that??
so if the sim card is the problem all i need to do is change it and everything will be good ???
thank you very much for your time and advice it seems to works fine without the SIM so you were right
thank you again
i did removed the sim card but the problem still exists what should i do else help me please
