Purple Spot on Camera Screen Xperia U
anandtapas
My phone is new and I took some photos with flash. No problem. But today after taking a pic with flash a purple spot(smear) has appered on the camera screen. Now all the pictures I take, even without flash have that purple spot on it. What could be the problem ? Sony please help !
35 REPLIES 35
kandros
i had 6.0.B.1.564 now i have 6.0.B.3.162
, but they removed 6.0.B.3.162 from servers because solved camera bug but suffer from a signal loss issue, just wait for ics, it will come soon, btw you can fin the image of the 6.0.B.3.162 build in xda and flash it
SolomonAnuGeorg
PLESE SEND UR EMAIL ID TO ME MY EMAIL ID IS :- Sagaudir8@gmail.com
SolomonAnuGeorg
Are U Sure About that
kandros
100% sure, my experience for both issues
sardar
iam also facing this problem what is the solution to fix that spot?
Bardia
It's because of its LED Flash,it is a little Purple,SONY fixed it by updated its software to remove this,but if you turn its LED Flash on,and compare it with other LED Flashes,you see it's a Little purple
supersuphot
That's not correct, It happen even flash off. Slightly_smiling_Face
Bardia
wait for ICS ( i know it's hard,because it seems we should wait for whole life ) ,my problem fix after updating to .184.
Mihai21
When I want to take a picture or video and i'm inside in the house,the picture/video comes on a purple color with some yellow points on the left.I changed the settings,i cleaned the glass camera,problem is the same,only inside in the house.I used the repair via Sony suite, but the problem is the same.Here it is the photo:http://www.imagesocket.com/pho...uest/2564­714  Now i have ICS 4.0.4.
dajcina
all of you must know the fact that XU camera on ICS in compare with camera on GB is practicaly unusable. and that is case with EVERY ICS firmware! i made multiple hand by hand comparision tests
with my and my wifes XU and only solution i'we find out till now is downgrade to GB. very sad is fact that most of ICS users are ignoring this and worst of all - Sony is ignoring too!!!
