Repair boot screen
tutundziev
Repair boot screen
can somebody tell me what is this my phone is stuck on this for 15 min now DSC_0006.jpg
Johan
Master
The screen you see indicates that the phone is repairing the file system.
This can take a while so connect the charger and leave it be until it's finished.
16 REPLIES 16
Danial-mach1
Leader
Image will not appear until mod user accept it.send pic link here
Thommo
Genius
You need to upload the image to something like box and post the link/url here
tutundziev
it's a triangle with a screwdriver and a wrench and a blue line going under but now it finished but now i'm facing another problem the album app wont update -.-
Sonysp09
http://d-h.st/uQR
Download it from here
tutundziev
Thank you very much now i'll just have to keep down and wait for a bug fix update
Johan
Master
Nefertaly
I'm having the same issue. I had the same screen.
But it's lasting more than two hours now. I can't enter my phone and it's stuck on a screen with theSony logo.
how long did that process last for you?
rockky
mine was stuck on that screen too ...I just did the vol up/down & power at the same time untill it did three vibrations and it was all good and after that and this screen doesn't appear again..!!
