Running Services in Sony Ericsson Xperia
Under Applications -> Running Services  I found many services which are running more than many X days. In that screen only below I see 'Avail and Other' with values has in MB. What does that mean?:smileyconfused: There are some unwanted service which is not needed to run and consuming battery as well. If i close those service also after one or two days I see same service running. How to come out of it?
slimshaddy
Hero
you cant close some applications , if you will they will restart..
so you cannot..
10 REPLIES 10
slimshaddy
Hero
so you cannot..
I too agree with your point but it should not be right? Any unwanted services can be closed by user ?
I talked about "'Avail and Other' with values has in MB" in above message . I see those values are getting changed under Running service screens. Example Avail 27MB+58MB in 20  Other:35MB in 3.   Two months back it was like Avail 15MB+35MB in 12  Other:23MB in 2. why I see a change in MB if same service is running each time? Thinking_Face
slimshaddy
Hero
yes this happens.. sometimes even you exit any application , it still takes some amount of ram which is not shown under the running services..
and yes RAM issue should be corrected.. there are many other problems with RAM...
so just restart your phone once or twice in 4-5 days , this will close all the apps and will free up RAM Slightly_smiling_Face
mark helpful and correct answers..
Sure I will Winking_Face
slimshaddy
Hero
any other query Dizzy_Face ??
Happy:smileylaugh:, marked all:smileysilly:. Honestly it was helpful one
slimshaddy
Hero
great Dizzy_Face
Yes I have:smileycry:. Not able to connect to mobile to my laptop. See my this Post and reply if you have any useful answer
Missed post name in previous reply  "Connect Internet using Sony Ericson x10 mini pro".
