Screen blinking / Flashing after lock
I have an annoying problem over te cell phone that after the screen is locked it starts to blink
and flash after every 5 mins it blinks for around 5 times
I have 2.3 Gingerbread OS.
I re-installing OS but nothing.....What should I do now???
please HELP.....!!!
7 REPLIES 7
Uliwooly
does it happen right after you repaired the firmware or after you installed or synced some apps?
Don't forget to mark the Correct Answers & Helpful Answers
This was happend after one month i bought the phone .i made format of all aplications and continue the same thing.my firmware is 6.0.A.3.73
Uliwooly
do you have a protective case? or extra film protector?
yes i I have both of these....but it was blinking/flashing before i bought these
Uliwooly
try w/o the protective case
is the protective case the realy problem???? and why???
