Screen memory/ghosting - temporary effect
The battery temperature was 30 to 32 degrees.
This is not a software flaw (tested several gallery applications and noticed during general use) or a camera flaw (what you see in the video is exactly the same in reality).
Can anyone explain the source of the problem and how can I fix this? Is this another yellow tint type problem of the screen?
FrontierGate
This is called transient image persistence, which can be seen sometimes when a bright image that was set against a dark background is replaced by a dark background only; this image retention is usually released once a typical-brightness image is displayed and does not inhibit the display's typical viewing image quality.
http://en.wikipedia.org/wiki/Image_persistence
Since they are replacing the LCD panel free of charge with respect to the yellow tint problem, why don't you ask for a replacement too?
5 REPLIES 5
Johan
Master
I have not seen this before and I'm not able to replicate it on my Xperia S so I suggest that you have yours examined at an repair center. Contact your local support team for more information about local repair centers.
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
I was wondering if anyone who have yellow tint could try replicating this problem. I suspect that my phone might be from the same faulty batch.
Although I haven't seen anyone complaining about my kind of problem.
mee too with this ghosting effect.
And I have also yellow spot Angry_Face
FrontierGate
Couldn't get a better answer, thanks! It appears my phone indeed was from the yellow tint batch as when the weather in the UK got hot I started noticing the yellow tint effects. Since this was a contract phone, my network provider sent it to repairs free of charge.
