Hello, i have a little problem on my xperia sp device, sometimes it lets me slide down the notification panel, sometimes it doesnt. I have reseted the phone and even an software update and didn't helped me.
Solved! Go to Solution.
Do you have a screen protector placed on your phone? You could also run a test via the Xperia diagnostics app to see if you have a digitizer issue
If Thommo's tip doesn't help, you should send in the phone to a service center for repair. Contact your local Xperia Support for more information.
Repair the phone with PCC and see if you experience the same issue again
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
i did that and it doesnt work
Contact your local Xperia Care
Anytime
