Sony Xperia t not charging
Sibles24
Recently updated phone, battery run completely down overnight now won't charge, connect to PC or anything, any help gratefully received. Thanks
24 REPLIES 24
dexan
Hi....... Mine is doing exactly the same.:smileysad: Have yo solved the problem?
Regards, Dexan
rawiri
I had the same endless loop, I tapped the phone on the table on different angles thinking the battery may have, Mabe come lose from its internal connection, it seemed to stop the loop, then I left it turned off while it charged all day, the red light was on n stayed on, it took all day to turn green, unplugged it be for turning it on, it works, but the battery shows unstable, jumping up and down 10 to 20 percent but worked fine until it got below 20 percent, n died, same system again to charge it. And works again. It now will hold charge while plugged in, but won't charge unless it's turned of, and still takes all day,
MARKP
My xperia tl is having same issue, just started day before yesterday.  now my wife's xperia tl is doing same this morning.  had success yesterday resetting my phone and started charging, held charge until night. plugged in overnight and is drained to 25% battery.  i did not let the battery fully discharge any time.  the phone is 1 1/2 years old.
roblaidler5791
I have a charging issue with my xperia t aswell, when I plugged it in there is no lightning bolt through battery to indicate charge but when I turn phone off and plug it it the red led comes on and battery without lighting bolt but still charges
Joaser2
I have the same problem here my xperia T turns off with 5% now it wont tun on and it wont charge eigther i tried everything possible to get it back on but it wont no lights nothing. if i buy a new batterry wil it turn on?even if the pc doesnt make any sound of connection?i need some advice please thank you
Gebjake
I have the same problem, even bought a new battery and took it to specialists but so far nothing happening and it's like it just died but, when i bought the new battery it turned on with the power from the new battery but on exhausting the power it has gone dead again. Anyone with any final solutions?
FranckStw
I had the exact same problem with my XPERIA Z5 compact ... And solved it!
Battery was at 3%. Not charging. I decided to reboot, thinking it is a bug.
It didn't start again. Tried all chargers, cables. Power+volume UP, Power+Volume Down.
Called Sony support Switzerland. Amazing people. Best customer service ever.
"Sir, do you mind removing your SD card, your sim card, and trying to charge it?"
I worked. Instantely.
Hope this helps.
AAXT
Hi, I want to publish my xperia t problem pleade suggest me.what to do.
When I plugin for charging, suddenly red light blinks.. then after 2 seconds screen open with red light but no sony display on the screen. Then screen off after 2-3 seconds. And it keep on going. Its not charging since so long. What to do please suggest.
nick666
Thanks FrankStw
Amazing this worked for me as well!  Wan't charging with wireless jacket or direct usb (no red light).  After removing sim and sd card the light came on after a couple of seconds!
Thanks!
Eszter
The same problem happened to me, I removed the Sim and SD Card then charged it for about an hour when the red light lit up and my phone started to work again. So the Swiss solution seems like the best for me, hope it is gonna work in the future. Slightly_smiling_Face I might have to order a new charger though.
