The message you are trying to access is permanently deleted.
I Want some help with the instuctions of
http://unlockbootloader.sonymobile.com/instructions
I have install SDK .
But I cant continue on step 13 .
My pc dont ask for driver as step 13 says.
(On your computer, you will be asked for drivers.
Point to the usb_driver folder where you placed the android_winusb.inf-file,
and select the Android Boot loader Interface-file.)
Can anyone help me ????????
Sorry for my BAD English ,
Thanks in advance !!!!!!!!!!
Solved! Go to Solution.
Thanks for helping but i found the answer.
To continue to step 13
must have
fastboot.exe , AdbWinApi.dll , AdbWinUsbApi.dll
from
Android\android-sdk\platforms-tools
to the folder that the cmd opens.
e.x.(c:\Users\Acer>)
And everything works just fine !!!!!!!
I suggest that you turn to Developer world for more information about this.
http://developer.sonymobile.com/about/how-do-i-get-in-contact/
But what is step 13.... I can't understand What is to br done ? Everything goes fine and I get stuck to
Awaiting for your reply
go to control panel->device manager
there u will see under 'other devices' section, ur device with an exclamation mark, showing its driver is not installed. right click on it & select update driver software -> choose 'browse my computer for driver software -> select 'let me pick...' -> show all devices -> have disk -> browse to the folder 'usb_driver' -> select 'android_winusb.inf'.-> ok -> select 'Android Bootloader Interface'.
dats it, ur drivers r installed. den continue ur next steps
NOTE: 'android_winusb.inf' file given by sony is probably corrupted as it didn't work for me. use the original inf file, which will show ur device as samsung fastboot device. but ur job will get done, as it did for me.... :smileygrin:
please can you email me full instructions how u unlock bootloader,,as in my device managerit doesnt appear any interface file to select..please guide me through full instructions abt this i want to unlock my phne..help me,,
Hello,
Everything goes smooth until 13, my device don't ask the drivers, how can i find it, i tried everything.
All drivers are installed.
Wish program will ask drivers anyway? flashtool, sdk manager, an pop upp window... i don't understand, please help me i am searching already for 2 days and still stuck at number 13
Thanksssss
Thx mate:) Worked like a charm!
Hello, I am stocked at no. 13, I choose update driver software, but there is no ''Android Boot loader Interface-file''. What can I do in order to install driver ?
Thanks in advance
