where can i get live wallpaper like ics 4.0 theme picture?
Shinee
hello there,
live wallpaper called cosmic flow was very attractive and why i dont have it on my ray ?
where to get tht thng ?
i only see tht lwp on xperia S
how to get tht on my phne ?
7 REPLIES 7
Shinee
thnk you Slightly_smiling_Face
gwhispererz
Champion
No problem.
seamo123
Sorry to butt in here but might you know how to access the Live Wallpapers in Xperia Ray Gingerbread 2.3.4?
I downloaded a Live Wallpaper that works fine - when I click on the wallpaper icon (that I just downloaded) it brings up a menu with various different Live Wallpapers that are preloaded on my phone. The thing is, I can't find any other way to access this menu - when I go to 'settings' and then 'display' the only option I'm given is to change the theme of the phone. And according to the 'user guide' on my phone there should be a 'wallpapers' icon on my homescreen so I can pick whatever wallpaper I want - this 'wallpapers' icon just doesn't exist on my phone - I've cjecked and double-checked! So basically I can't access the Live Wallpapers menu by 'normal' means.
Any ideas anyone?
gwhispererz
Champion
Hi Seamo123, longpress on homescreen, select Wallpapers>Live Wallpapers, you should have the options to choose.
seamo123
Aha! Problem solved!
Thank you! Slightly_smiling_Face
gwhispererz
Champion
No problem .... Slightly_smiling_Face
