I have rooted my Xperia Neo V.. so i want to explore the Rooting World
So please Suggest some Best ROM's for Neo V
Solved! Go to Solution.
Okh then
Xperia Pureness Rom above is good ( simple to install ) (1 )
http://forum.xda-developers.com/showthread.php?t=1737862
Now there are many well knows roms out there, you have to find which one is best according to you
Try all roms
http://wiki.cyanogenmod.com/wiki/Sony_Ericsson_Xperia_Neo:_Full_Update_Guide
http://forum.xda-developers.com/showthread.php?t=1480273
http://forum.xda-developers.com/showthread.php?t=1721957
http://forum.xda-developers.com/showthread.php?t=1570499
For custom Roms, you need to unlock your bootloader
You can only install themes
1 http://forum.xda-developers.com/showthread.php?t=1737862 ( Can be called as rom )
2) http://forum.xda-developers.com/showthread.php?t=1601475
3) Find here http://forum.xda-developers.com/forumdisplay.php?f=1276
I Hav unlocked my bootloader
Okh then
Try all roms
Which is the best rom for xperia neo l
Pureness-http://forum.xda-developers.com/showthread.php?t=1737862 as suggested. go for build 14,you need to search in here
(Awesome battery)
Ultimate HD-http://forum.xda-developers.com/showthread.php?t=1947430 (Awesome Gaming)
And you said you have unlocked bl! you gonna have fun bro!
I've used both of them!
Faaaar better than stock ones!
Kitkat is best for Sony Neo V as it has 512MB RAM and Kitkat is optimised for 512MB RAM. Ultrakat ROM I tried and games are seemless without any lag.
Link:
http://forum.xda-developers.com/showthread.php?t=2657641&highlight=haida
Legacy Xperia project is also good. CM11 is unoffically buit for Neo V.
