The message you are trying to access is permanently deleted.
After having installed and uninstalled difffernt apps in my phone i get the following message when trying to upgrade the SW in the phone:
"The phone contains modified software that cannot be updated"
I also tried the repair option without success.
So how should i proceed from here?
Accept the fact or?
Is there any solution other than leaving the phone to a repair center for total reload of SW?
Carl
Solved! Go to Solution.
Did you unlock the bootloader or anything?
Did you update the firmware from a site like XDA or something? That would do it.
Yes unfortunately i rooted the phone since i tried to remove some unnecessary pre-installed apps.
So how should I proceed? Is there any DIY solution to this problem or just accept the fact?
Carl
