Xperia Arc black screen
Hi all,
I have my Xperia Arc since beginning of September. And sometimes, I get a black screen on my phone. Unable to restart the phone or do anything with it. The only way to manage this is to remove the battery and place it back. Then I can restart the phone normally.
Last time, my battery was at 32%. I have Androïd 2.3.4 and use firmware version 4.0.1.A.0.283
Any idea of what can cause this? Is it the battery itself?
backup everything and repair it with Update Service/PCCompanion
6 REPLIES 6
Backup & Restore app
Use this links to download the apk
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Ok, I tried this. We will see in the next days if it happens again. Thank you for your reply.
But now, I have a huge question : Firmware version 4.0.2.A.0.42
What is this? I didn't even knew that version was available.
it seems to be a newer version of the firmware, it doesn't seem to add anything new to it.
the only big difference are few extra apps
Sorry, I couln't reply earlier.
It happend 2 times again. But there was nothing wrong with the phone before. It just stops.
I have absolutely no idea about what is causing this. But good point, once a month is not too often for me. Thank you, anyway.
