Hello,
I ve a new Xepria mini pro that has an update for Track ID but when i downloaded it, didnt remove the old version and was installed as a new application,
how could i make it replace the old one or remove the old one as i ve the new version ??
Thanks in advance.
Solved! Go to Solution.
hi @john_90...well yes u can't uinstall the older version..as it comes along with phone as a in-buit stock application...the older and the newer version is seperate..!! i'm using the both..hope u got it....!!!:smileylaugh:
no need to remove the older version
when u updates something, older version is automatically un-installed and newer is added
I already know that from various updates, but in this case when the app sending me to the market has only install and not an update like every similar app updated be4 it
oooo
i got u now
go to settings > aplications > manage applications > all > select the app u want to uninstall
remember : u cannot uninstall the app that came with the mobile
Thats why i hoped someone could help me and say where is the problem as it should be replaced with the new version and in the same time it came with mobile and i dont want to see 2 same app one old and one new
now, is ur problem solved ??
keep the original sony app
its a good one
U got my answer wrong i could not uninstall the app and was talking to sony chat room now and there no solution except to use both
most likely the upcoming ICS update will solve this..dont forget to mark my answer as correct and helpful..!!:smileylaugh:
