Some strange pictures appear in the gallery but I dont know how to delete them. Every time i try to delete them the application crashs and is closed 🙂
Solved! Go to Solution.
Remove every account from auto sync and see if that helps
Settings > accounts and sync > selct/ facebook / google/ etc > menu button > remove account
Then see how it goes
Have you enabled auto sync ? i could be due to that
Try settings > applications > all > gallery > clear data and cache
Do you sync with Facebook, Picasa or similar?
Check by going to: Menu > Settings > Accounts & sync.
Hi, Thanks for your suggestions guys but none of them worked. I tried turnning off the facebook, picasa sync but without any results. I can't delete the photos 😞
go to settings -> applications -> running services stop most of the apps -> open the gallery app -> if those pictures re-appear -> settings -> applications -> running services it has to be an app acting up
I also get this on 2 pics that appeared in my gallery that I can find no way of removing!
which accounts are you syncing?
Seems to be Whatsapp, Facebook inside Xperia, Twitter and Gmail
it's probably one of those apps that it's syncing those pictures.
