I am having problems connecting to my home wifi connection with my sony xperia s. I can connect to my work wifi connection fine, however my home connection is not going through. The xperia sees the connection and allows me to enter the network password as well but no connection. I have also tried the auto connection option and no luck either. All other devices at home connect fine such as laptops and iPad. In addition i have tried finding my device by accessing the router through my laptop and no luck seeing my xperia either. I have a Cisco WRT610N router.
Solved! Go to Solution.
Have you checked the details listed here:
I updated the firmware on my router and the Xperia S connected instantly. Thanks for your help!
No problem, I'm just glad is sorted out for you now
