Hi!
Yesterday night my phone turned off while I wasn't looking and now I can't turn it on, I connected the phone trying to recharge it (I thought that was my problem) but I left it that way for more than 10 hours and is still death! First, nothing happened but a while later the red LED appeared but that's all
I don't know what is wrong with my phone... and I have had it for less than 2 weeks...
Btw, I tried pressing and holding the power buton and volume at the same time for 5 sec and 10 secs but as you can imagine, it didn't work...at all.
Solved! Go to Solution.
do you have another charger? and/or micro USB cable to test?
Don't forget to mark the Correct Answers & Helpful Answers
what happen when you connect it to the wall charger?
the red led but that's all
the one from my xperia x10 but they have a little difference so I'm not sure if it's safe or not 😕
any micro USB will work, even if it's not from Sony
keeps doing the same => nothing but the red light =( thank you anyway
Forget what I said.... It's working again!!!!!!! Thank youuuuuuuuuu!!!!!!!! :smileygrin:
Anytime
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
