I have recently paired my Sola to a new car via bluetooth. The pairing went well and all contacts downloaded after a false start. The phone performs as it should for hands free calling and receiving but there is one annoyance that I cannot seem to find a solution to.
For some reason when the phone is connected the Walkman app is triggered and starts playing an audiobook through the car system. I cannot find a way to disable this permenantly and have to resort to opening the Walkman app and manually stopping the playback. The app will then restart after the phone has been used.
I am sure there must be a simple explanation and hope that someone can point me in the right direction
Solved! Go to Solution.
Sounds great. SmartConnect is an updated version of Liveware manager which I believe was pre-installed on Xperia Sola, so it won't mess with anything :smileyhappy:.
Looking forward to see the results, would be great to know it it works, for future questions regarding the same issue.
Good luck!
Well it seems that SmartConnect did the trick as my phone and media work as expected after the download
I will list what I did as accurately as I can remember hoping that this may be of some help to others in the future.
So once again many thanks for your help on this
I'm glad to hear! Yes, SmartConnect is replacing Liveware manager so that's all in order.
Thank a lot for the feedback, it's always nice to know if the solutions worked or not. Many people don't posts after you've replied with a possible solution so you never know if they gave up or your solutions did the trick :smileyhappy:.
Have a nice weekend!
I found a SmartConnect to be a nice app that autostarts Night mode when I connect my charger in the evening - really cool!
But when go to drive my car, the same issue that is described here appears (3 years later, still unsolved). I found a place where Walkman is listed in mu car BT device list, but there is no place to remove Walkman from that list or disable autostarting a (random?!) music file when I start my car.
Is the only solution really to completely disable the Walkman app (its not possible to uninstall it as it came from factory setup)?
Kalle
Xperia Z3 Compact
