Deel jouw ervaring!
hello, i just want to ask, does it damage the battery when we leave it charging for too long after it reach 100 % ?
Opgelost! Ga naar oplossing.
No,these are new tech batteries,they do not charge after reaching 100% and it says full charged in settings-about phone.
no it does not if you are having problems with battery, got to settings>apps>all , scroll down till you get to Eco mode controller , open clear data and restart handset
eco mode controller was there before and i have reset it several times , but now i just check it and eco mode is gone and a i have is extended standby mode controller
check if your standby mode is on as i dont see the standby mode controller on my handset . if its on , turn it off and reset Eco standby mode and restart your handset
For the eco mode controller,you need to disable stamina mode, go to settings-apps-all-eco mode controller,force stop,clear data and restart the phone.
eco mode was there before , but it recently gone and i don't download any ampps to extend my battery life besides stamina mode here i give you my screenshot
Very strange that eco mode is not there anymore.
turn off stamina mode
