Xperia SP hard reset problem
ugurkaya
Hi guys, I have got a problem with hard reset (volume up+power key combination). It does not work at all. I've waited pressing these buttons for about 1 minute and nothing happened. Also tried this when screen locked, when unlocked, when phone switched off. No change, no effect.
Tags (2)
23 REPLIES 23
Sennaisen
It will damage your back case cover tho if you remove it very often, because it is very fragile (hooks)
karinaav
i seriously love people like you. thanks
amit1
My sony xperia sp hving problem with volume key..when i listen songs using headphones volume automatically decreases to zero..when i increase volume again it decreases to zero..again and again .
QualityServices
Hi
I tried this method but its  useless for me...
But i am unable to reset my sony experia sp
My sony expira sp is going reboot again and again continuously.
First expira logo coming after that color layer and again rebooting....
I am worried...
Please help me...
Danial-mach1
Leader
you can repair your phone with sus
pankaj0605
hi ..did u  get the solution..i m facing same problem
Danial-mach1
Leader
What problem pankaj?
Smod
Amit are you sure your phone isn't just receiving messages? When any message, chat notification or any important notification appears, the volume of the walkman will reduce nearly to 0 and then back up. Depends on whether you have left the phone on silent then you wont hear anything, otherwise you will hear the notification chime!
atritmoe
I have a problem like that. But now it's fine...
thanks 4 your post....:smileyyahoo:
Juv
Thanks very much, your information it's corret,  I could  reset my xperia sp.
