I updated my SP like normal, and as soon as it booted, it is so much slower than it was before, can someone please help me to fix this, or help me return it back to the older version of android, where it was fine?
Thanks in advance.
Solved! Go to Solution.
Its very odd but Im sure you can get rid of it by either software repair or factory
Cause I've done it
But I know you prefer to wait for new update.. How ever after that you must do one of above suggestions
> So darn awful slow after the update to 4.3 ... yesterday I couldn't even accept an incoming call because the
> screen wouldn't display it. Chrome just straight up crashes when started.
reset the phone and installed the update via SUS again. it got a little better (chrome works again). but overall still laggy and I still have problems accepting calls because the screen takes forever to display the call and let me accept it. no addational apps installed, even deinstalled some of the crapware that comes automatically whan installing/updating the firmware.
Congratulations Sony, now I have a smartphone that 'sometimes' can be used as a telephone.
Schulze
Exactly the same problem here..
My 'phone' can load a game, but it will stop responding when i try to open messenger/dialpad/contacts.
Repaired 3 times, factory reset before and after.
@alb8 i know i have them freezed (probably i wrote that post wrong way)
What I don't understand is this:
When I had Xperia J with 512 mb ramI had cca
180 mb free. Now on Xperia SP with 1 gb of ram I have cca 200 mb free.
I am not gonna make next reinstallaing with sus, repairing with pcc or factory reset because it will not solve the problem. I have done it more then 5 times and ram problem still goes on.
But Xperia J's last firmware is Android 4.1, whereas Xperia SP uses Android 4.3, which uses more RAM by default.
It's not totally comparable situation.Most problems can be solved with SUS and factory reset afterwards, but increased RAM usage is one of Android 4.3 "features".
Do give few days phone to "settle down" after reinstall, it cannot "tune" itself instantly.
Hello.
Did all those resets and Sus, 2 times, but i dont think this is good. Ram usage is high.
Oh, and the phone settled few days after SUS, and reset. good thing is it wakes me up in morning.
Well no use of resetting for common issues rather these should be told to Sony to release update to cover these. I guess Sony is going to release one update sooner to cover most of the common issues. Let's see.
