3D and Component feed
jimtellycon
Hello
Can anyone advise if I can get 3D on my KDL46HX823 Bravia through the component input.
4 REPLIES 4
Hi there
Short answer = NO
Long answer is =
Am I assuming that you have a Bluray player that is capable of 3D, and is connected via component inputs? If thats the case, replace the lead with a HDMI 1.4 cable. There are some really good ones on Amazon and at a cheap price too. You wont be sorry.
If its not a bluray player connected? What device is it?
Cheers.
Bravia55HX
its highly unlikely a component cable is capable of carrying a 3D signal so i'd say no.
Rich.F
Surely it would be quicker to try it?
As one of the previous answers stated a HDMI 1.4 cable will do this no problem. If you search ebay for a high speed hdmi cable, then just look for one that is 1.4 you should pick one up for around £3
A 1.3 will carry the video signal no problem but not full 7.1 audio. Besides its better to be future proof as best as you can.
jimtellycon
Hi Rich
The original question was can my Bravia TV get 3D tv with component feed. I know it works ok with HDMI but I have a multiroom system that works on Component and gives me HD ok but not 3D and I am trying to establish if 3D is posible  through component feed.
