3D TV KDL40EX724 and EX723
littlelady
Thinking of buying a Sony 3D from the sony shop with the 3d package included on model KDL40EX724 but I noticed on line John Lewis and Richard Sounds are offering a cheaper deal on the KDL40EX723 and I just want to know what the differences are between the two models? Can anyone help before I buy!
Hi littlelady,
The EX724 has built in WiFi to connect wirelessly to your home network.
The EX723 does NOT have built in WiFi and you will need to buy a Sony USB WiFi dongle (UWA-BR100) for about £50 if you want to connect wirelessly.  However if you only intend to connect by network cable, you can save yourself the £50
Those deals look good.
:wink:
Bravia55HX
well on the Sony site the difference is £50, but with a deal like that from Richer Sounds you cant go far wrong, but i will say this (get the five year warranty) for it as well and you'll have no worries for that period.
Hi littlelady,
:wink:
