42w815B Sony telly
42w815B Sony telly
Is there built in wifi on these telivisions and if so how do I find the code?
Hi there
Yes, Wifi is built in.  See specifications : HERE
Unsure on why you need a code?  Have you connected the TV to your home network - as its just the routers password.
Hi there
