Access to Picasa from KDL 40 Ex 700
johnkubale
After many rejections of my Google password which contained upper & lower case and numbers I changed to lowercase 8 characters and it worked. The default size photos do not fill the screen but are about 1/3rd of the horizontal. There was no problem with over 100 albums. I noted this problem had been posted many times.
Hi there
This is probably something that these forums may not be able to help you on.  As Google create the picasa application, I would suggest that you post your question on googles forums:
https://productforums.google.com/forum/#!forum/en
If all else fails, try contacting Sony Support:
https://shop.sony.eu/shop/mimes/openAccess/legal/contact-us/contact_en_GB.html
