Solved! Go to Solution.
Hi there
From my understanding the Aerial Loopthough is OFF by default on the YouView boxes. You need to enable it, by going to Settings > Device Management and enable RF Loopthrough (I think).
This will enable the signal to by-pass the YouView box and onto the TV (its a single aerial cable solution, instead of a 2 cable/splitter).
Hi there
Hi there
Choose Digital > Antenna (or Aerial)
