Alternative to widescreen format?
merryfrog
Why does my TV sometimes not show the full image being broadcasted at the sides of the screen eg words at the left and right side of the screen in a subtitle can be missing. Changing to wide screen format doesnt help. I receive the broadcasts via satellite if that makes any difference?
profile.country.hr_HR.title
DamacizSi
If You connect TV to normal antena and hit auto start up, You will become DVB-T program and  You will see is it satelit broudcast problem.
Regards
Damac
