Apps do not run until I run "refresh internet content" - KDL-32WD751
JimboEd
The TV connects to the internet fine. I have setup the DNS to 8.8.8.8 and 8.8.4.4. However, the apps will not run until I run "refresh internet content" after initial power on. I took the TV to the store I purchased it from and the apps run without needing to run "refresh internet content". Can I make a settings change to the TV or my router which will allow the apps to run without this annoying step.
I use a static IP address for the TV and have the router also use the same DNS settings. None of that made any difference.
Thanks in advance
11 REPLIES 11
JimboEd
Have you looked at
https://community.sony.co.uk/t5/other-tvs/bbc-iplayer-not-working-brand-new-tv/m-p/2236487#M47005
This has the symptoms of your problem and the thread is shown as solved.
Hope this works for you too.
Jim
Joe_Dohn
Specialist
@JimboEd Glad to hear the issue is resolved for you!
@Mattielulu
If neither of the threads (this one, or the one just mentioned) solve your issue, try creating a new thread so that people don't get confused and you can get the help you need directly.
Hope this helps!
- JD
