Assign new channel numbers to digital channels
profile.country.sv_SE.title
bada113
How can I assign new channel numbers to the digital channels? I have a Bravia KDL 46W5500. Seems that it is possible with the analog channels but not the digital ones.
Pcadjb
Hello,
          I don't know if this is same as KDL-40W5800 (Satellite model), on my set it is as follows.
1. Press "Home" button to get menu on screen
2. Scroll left to settings tab
3. Scroll down to "digital set up" - press enter
4. Scroll down to "digital tuning" - press enter
5. Scroll down to "program table" - press enter
6. When you see the channel you want to change example ITV2 move from 8 -> 3
7. Move cursor to ITV 2 on 8 and press -> on remote (bottom of screen shows "Move"
8. Move the channel upto 3 and press <-
9. This will now put the channel that was on 3 -> 8, and the channel on 8 -> 3
Hope this helps.
