av sender
gino_12
av sender
Hi
Can any one help?     I have purchased a Sony Bravia 26ex55 and want to connect my av receiver to pick up my sky box from another room, on my old telly I just plugged in the red yellow white Jack plugs, on the back of the Bravia there's no colour coordinated Jack plug slots
Can any one advise me to which Jack plugs go where or do I need a different av sender?
 Thanks in anticipation
Hi there
I am assuming that your model TV is actually KDL-26EX553.  If so, at the back of the TV, there is a SCART socket:
What you need is one of these (SCART to Composite converter):
There are many Amazon, and are only a couple of £
Hi there
gino_12
Hi
Thanks for the reply, I will search Amazon and get one, thanks again
