BBC iPlayer no longer loading on BRAVIA TV (Dec 2013)
Help please,  Yesterday Iwas the first time I gave been unable to connect via my Sony Bravia tTV to iBBC Player
A couple of days ago - when watching regular TV - message boxes suggesting use of alternate HD channels pop up when, for instance I am watching BBC1.  Since these appeared I am unable to connect via my Sony Bravia TV to iPlayer. All other internet connections are fine and it loads 5 on demand, Sky News, YouTube etc fine. The only fault is with iPlayer.
I have been through the Bravia systems and used Fadtory Reset and reconnected and checked my broadband  wirless network - I use Virgin Media n- all of which do not solve the problem,
When trying to load t I get a fault screen stating that there may be Netwirk issues.
Any assistance/advice would be very gratefully recieved.  Thank you.
Re: BBC iPlayer no longer loading on BRAVIA TV (Dec 2013)
Also got same problem with KDL-46HX823. BBC iplayer been working fine for aound 2 years. This is not a networking or internet issue. Found the same problem on my BDP-490, but firmware upgrade + internet content refresh fixed the problem. However, iPlayer then took around two minutes to 'download' and start. I suspect the BBC have changed something and the TV is timing out the connection. On the TV I get an opera display stating 3 possible failures to display the target . page. i.e. - URL incorrect, Network problem, Internet problem. If you hold down the select key on the remote.you get a second page displayed for around a second which has the text '/bigscreen' in it. Unfortunately is is not displayed long enough to record the full text..
This is a major problem for us as we use iplayer a lot.
Sony need to investigate this problem urgently
We are having exactly the same problem, our samsung smart tv loads iplayer. Sounds like Sony have a problem!
Master
Hi there
BBC iPlayer is down at the moment.  The BBC are aware of the problem and are investigating.
https://iplayerhelp.external.bbc.co.uk/help/announcements/sony_devices
Afternoon.
My colleagues in the Product Quality and Engineering team picked this up yesterday and are now looking into it.
As soon as I hear more I will let you know.
Lee.
Dec 13th
iPlayer not working 3 days now!
What is the problem all other internet services on my Sony kdl40ex72 are working.
I have a feeling this is as Sony problem.
Any answers please
David Ward
Master
Hi there
Incase you didnt notice another thread on here, see:
http://community.sony.co.uk/t5/Televisions/BBC-iPlayer-no-longer-loading-on-BRAVIA-TV-Dec-2013/m-p/1...
My BBC I PLayer has also stopped working - the other sites e.g channel 5 still work fine
I Baught a new BRAVIA KDL-42W664A and BBC iplay just says "The service cannot be accessed at this time" but it works on my laptot, Wii, and XBox any clues?
iPlayer has also stopped working on my Sony Bravia KDL22EX320 since last night, I can access it fine on my laptop and everything else on the Sony Bravia is also working ok. It looks like this is becoming a widespread problem.
I tried a manual firmware update, but a message came up that the update wasn't applicable.
Anything you can tell us Sony?
