I have a Sony Blueray and a Sony Bravia KDL40EX503. The Blueray displays iPlayer Radio as well as TV, but the Bravia shows TV only. Is there a solution to enable the Bravia to access BBC radio?
Solved! Go to Solution.
That would be down to the BBC to roll out ultimately. iPlayer on BRAVIA is basically the same as the Freesat solution and so when BBC update it on Freesat, then it *should* also be updated on BRAVIA.
What is going on with Sony equipment 1st they cannot connect to ITV/I player and now on a TV less than a year old No BBC/I player. really this is not good enough Sony or is it BBC , please some one help.
Please fix this issue.
See this thread for more information:
