Bravia 32WD756BU not recognised by Sideview
simon3030
Recently bought a Bravia 32WD756BU TV,  but when trying to use Sideview,  add device,  it can't find it even by typing in the correct IP address.
Any thoughts?
Thankd
Hi there
I was just about to reply to you about checking network settings etc etc, but thought it was worth a look at the Sideview compatibility list.
http://info.tvsideview.sony.net/en_ww/home_device.html#bravia
What is interesting is 2016 Non-Android based models are not supported.  Your TV model is under "KDL-W75xD"  I am struggling to find a plausible reason on why Sony would do this?  At the moment you're out of luck on this, but 'hopefully' they will enable compatibility in the future.
