markw886
Bravia 40HX803
How do I change the language on the menu on a Bravia 40HX803. Just bought it and the menus are in Polish. Can't read it to change it to English. Help!!!!!!!!
Tags (1)
bryfly
Try this, go to home menu and then furthest left to a "small case" sign then to a symbol that looks like "3 draws", click on that , then go go down 4 spanners click on that , then on mine englsih is the top language, click on that, then should be ok..........hope this works for you..........
markw886
Brilliant, thank you very much, all works in my native tongue now. Just for interest since this is a world wide web, where are you at. Just curious as to where  the answer originated from..
bryfly
Hi Markw,  Glad you managed to get it sorted from that garbled description, location is near portsmouth.......
