Bravia KDL-32EX403 Will not verify video settings when setting up a wired connection to internet
Sonysilversurfer44
I have connected my TV to router with Ethernet Cable but TV will not verify video settings etc. altough it says I am connected OK. I have tried all the options stated in various forums but without success. My software version is PKG4.114EUL 0108 and the software update has always been in the automatic update position.
I realise this is an older tv but it should still connect.
Why cannot I get the internet on my Sony tv? Should I be downloading a newer version.
Any extra help gratefully accepted
4 REPLIES 4
Sean_Mc
Moderator
Hi Sonysilversurfer44,
Can you let us know if you are getting any error message? If yes, what is the error message?
Thanks,
Sean Mc
Sonysilversurfer44
It merely gives a 0 return. I have tried re verifying but the same thing happens.
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
Sonysilversurfer44
I have tried yet again to get connected but with the 0 response.    Any help would be appreciated as I really would like to get my TV online (so to speak).
Should I try to up date the  version even though it should have done so automatically?
It is very galling not to be able to connect properly and I see that plenty of other folk have had the same problem.
Sonysilversurfer44
Hi Sony community.   I was hoping for some advice regarding my connection problems but am surprised I have not received help.     I see that many people have had the same problems ....  beginning to feel that Sony could not care less...
